2003 brake light fuse keeps blowing
Old 07-04-2013, 05:39 PM
msbblu's Avatar
Default 2003 brake light fuse keeps blowing
03 Chrysler sebring lx sedan fuse for brake lights keeps blowing put new brake switch in & sill blowing fuse. Changed light bulbs & still no lights. checked wiring going to lights & they look good. What could be making my fuse to blow. please help can't drive with no brake lights
Old 07-04-2013, 09:41 PM
You will need to check the wiring from the fuse to the bulb. There will be a short somewhere. If there is collision damage, start there. Look at places where the harness passes through sheet metal.
Old 07-24-2013, 09:28 AM
msbblu's Avatar
I have looked at wiring from fuse to bulb & it looks good. I've had 2 people that were car mechanic & they can't find short. Now my stereo is messing up A/C control will set 4 cooled then after working 4 awhile will start 2 blow hot my front lights & dash keep dimming every once in awhile. Another thing is it seems to use more fuel. Someone told me the car needs new brain. Y can't cars be like the older ones simple 2 have running & work on?
Old 07-24-2013, 04:29 PM
Y'know, if you prefer the older cars, there's nothing stopping you from going out and buying one. There are lots of them out there: no computers, no fuel injection, no airbags, no antilock brakes, completely mechanical and analog. My granddad's '54 Mercury was a perfect example. 6 volt electrical system and a radio that used vacuum tubes.
In the meantime, you might want to go somewhere that has a DRB III and have them search for error codes. Your body computer might be having issues.
Old 07-26-2013, 04:25 AM
msbblu's Avatar
I just might do that but the Car would have to have A/c I live in AZ & must be able to push amp & my subs. I'm going 2 go 2 shop & see what error code is in the morning let u know what it says.
Old 07-26-2013, 11:01 AM
a short to ground will not show any codes The issue when it blows the fuse needs to be present when they look for it our U let them have it and drive it around until the short is touching the ground to which they can find it then .
Old 07-30-2013, 02:48 AM
msbblu's Avatar
I found a few wires that I barely could tell that were cut which was the a/c control plugs now need to find other wires that are cut
Old 07-30-2013, 09:25 AM
Good work! You could have paid a highly trained technician $90/hr to do the same thing. Something like that is just as hard for an expert to track down as anyone else. It just takes persistence.
PolarisCobra
07-10-2007 03:06 PM
prince71
10-20-2006 03:49 PM
prince71
10-19-2006 12:55 PM
ragtop71
07-13-2006 03:54 PM
v1rott
05-08-2006 08:23 PM
Quick Reply: 2003 brake light fuse keeps blowing
