Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 02-16-2012, 12:20 AM
Question 2003 Chrysler Sebring Keyless Entry Remote Programming Help
Hi, we Just purchased a 2003 Chrysler Sebring convertible but the car did not come with any remotes I did call some Chrysler dealers they want $75 to program are new remotes. I did find some instruction online that said you can take a wire or paper clip and running it from pin 1 to pin 4 to do the programming would this work for my car I just want to make sure any Help would be appreciated
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 02-16-2012, 08:17 AM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
U will need to go to the dealer to program remotes the only way a cust can program there own is if U have 2 working remotes already and don't put any paper clip into any electrical socket with out knowing what is on that circuit
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 02-16-2012, 09:19 AM
2002 Chrysler Sebring
Totally agree with CHRYSLER TECH. I purchased a 2002 Sebring LXI this last November which had no remote entry included. I bought two used remotes from a reputable Ebay seller for like $25 for both. My local dealer programmed them for $29.00. It took the guy about 5 minutes.
Old 02-16-2012, 01:15 PM
Question
Thanks for the help here is the programming instructions I found online is this for a different year?
Here is a quick HowTo on programming your own keyless entry:
1) Turn ignition to OFF.
2) Locate the Data Link Connector, its a black 16 pin connecter that is under the driver's side dash, right where your right knee would be. You have to look up into the dash from below to see it.
3) Ground pin 1 of the Data Link Connector by taking a wire or paper clip and running it from pin 1 to pin 4. Pin 4 is ground so you can just short pin 1 to 4 and it will be grounded. Grounding pin 1 tells the system you are ready to reprogram it.
4) Close all of your doors.
5) Turn the key to ACC then back off. The power door locks will lock/unlock. This is the signal that the system is ready for reprogramming.
6) Push a button on your key fob, doesn't matter which button.
7) If you have 2 key fobs, then press a button on the 2nd fob within 1 minute of pressing a button on the 1st fob. Both must be programmed at the same time. If you only have 1 fob then press a button 2 more times to signal that you only have one.
8.) The doors will lock/unlock to signal the codes were received.
9) Remove the jumper wire from the data connector.
Old 02-16-2012, 01:53 PM
as I said dont put anything into any wire connector unless u know what it is you are doing.
Pin 4 is a ground pin 1 has no wire there to start with so best of luck with that
__________________
KKeller608@aol.com
Old 02-16-2012, 02:50 PM
Let us know how this goes for you RC2003 when you've completed the programming.
Good Luck!
Old 02-16-2012, 05:07 PM
My Garage
Those instructions you quoted are for a Dodge RAM van. They won't work for your Sebring. Teddysmith has the right idea.
Tags
2002, 2003, chrysler, connect, entry, fob, instructions, key, keyless, lxi, pin, program, programed, programming, remote, sebring, work
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
