2003 Sebring wipers not working
Old 10-28-2014, 08:26 AM
2003sebring's Avatar
Default 2003 Sebring wipers not working
2003 Sebring LX, 2.4L, 4 cylinder, sedan.
Fuse is ok. Fluid works. Replaced the switch in the steering wheel and still won't work.
When turning the wipers on, nothing happens. No noise. Washer fluid works.
Should I try replacing the motor next. If so, any tips/how to?
I don't have any diagnostic equipment to test for power getting to the motor, etc.
No check engine light.
Old 10-28-2014, 02:33 PM
with no way to test it then yeah get to throw parts at it until u get it fixed.
Best thing is to buy a service manual for your repairs
Old 10-29-2014, 07:35 PM
You can buy a multimeter for a lot less than you'll spend on replacing good parts:
Search results for: 'multimeter'
Old 11-06-2014, 08:30 AM
Found the solution.
It would appear the ground for the wipers was corroded and needed fixed.
Contact
03-01-2013 07:56 AM
44ark
04-04-2012 05:38 AM
dlm4ut
06-09-2010 10:32 AM
supertek57
02-16-2010 08:30 AM
NisCAPE
06-01-2008 06:54 PM
Quick Reply: 2003 Sebring wipers not working
