Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 09-30-2011, 06:38 PM
CJ3 CJ3 is offline
Default 2005 Sebring A/C - Electrical Problem?
A couple of months ago my A/C and environmental control panel started to act funny, and only work intermittently. When it worked it worked, when it didn't all I had was the dashboard defog blower, no control over temp, and unable to use the electric rear window heater. Finally it got to a point that I noticed it only worked when I parked my car at the end of a drive. Funny I thought...So I started putting my car in park at red lights and stop signs, yet the system would not work.
Today I determined that the reason the system would work when I was about to get out of the car after a drive, because I turned off the headlights. I tested it out today, and low and behold, the A/C and environmental control panel works fine, with the headlights off. As soon as I put them back on, the system powers down. So this leads me to believe I have an electrical problem.
I had my battery tested today. 12.7 volts static, 12.6 volts engine running. Alternator is good.
I am thinking what is happening is with a low volt battery, the alternator is compensating, and eventually load shedding. Would putting in a new battery solve this problem? Any suggestions?
Thanks in advance.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 10-01-2011, 10:18 AM
2002 Chrysler Sebring
My Garage
You probably will have a better chance of fixing the control head problem by replacing the control head. It's a fairly common part, having been used on all non-ATC Sebring sedans and convertibles and all Dodge Stratus sedans from 2001 to 2006. The part comes up on eBay occasionally. Or you can cruise your local junkyards.
Removal is easy. Pull the bezel surrounding the control from the bottom using your fingers until the bottom pops loose. With a plastic trim tool or a wooden paint stirrer, pry off the bezel, reach behind and unplug the wires.
Going to defroster operation is the default failure mode when the computer detects some failure in the control head. In these cars, the controls on the dash are only there to tell the computer what you want to do. The body computer actually sets the heater to do what the controls say.
Tags
2005, ac, air, battery, chrysler, conditioning, controls, display, electric, electrical, problem, problems, sebring, winning, working
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
