Put the front end up on good solid jackstands and run the wheels up to speed. Then listen for the noise. You should be able to narrow down the area with much greater precision. If the noise goes away, then suspect the other wheel bearing.
Be careful.
I did precisely what you said. I did it pretty low so in case there was a safety issue the car wouldn't be falling very far (1 inch or so) and the only thing that would get damaged would be the car and/or jack stands.
With the spedometer reading 20-30 miles per hour, the sound was there - but a different pitch. I assume the pitch difference was because the wheels were off the ground and thus encountered much less resistance.
What is interesting to me is when I put the wheels up to speed and turned the steering wheel the sound did not attenuate like it does with the wheels on the ground. I turned the wheels all the way to the right and left and the only difference in sound is when I briefly hit the stops on either side.
In the interest of a full investigation, I tried this experiment in all gears provided - Reverse, Drive, 3rd gear, and Low gear. The sound was present in all of them, and the wheels turning left and right didn't change anything. When in reverse, the sound was a little different, a lower pitch - but still approximately the same volume.
Does that tell you anything at all?
Additionally, my father was on the outside of the vehicle. He put his ear near the left side and then the right side wheel while they were at speed and he could not tell a difference in sound.
Thanks in advance for any advise you can supply.
