Rad fans always running
My rad fans are running whenever the engine is running. When I start the car, 30* out side temps (01 convtertible) the fans are on HI, if I remove the HI fan relay , they run on low untill I remove the low fan relay. The AC is toped up and works fine. This happens when the heater is on so it's not the AC demanding the extra cooling. Any help would be great.
Mike
Mike
RE: Rad fans always running
In addition to your temp sensor and associated wiring, and your pcm, your a/c controls can also call for the fans to run. (Assuming there is a malfunction in that system.)
95ImpySS
13
08-23-2011 12:42 PM
