Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 08-22-2011, 04:48 PM
Default 96 sebring nightmare (timing,no fire)
so i was doing my friend a favor and replacing his distributor cap and rotor, plain and simple, i fu*ked up by not marking the rotor and now the timing is off, i cant find ANYTHING online about the rotor and where it needs to be, all i found was that the number 1 cylinder has to be top dead center and that was it i've taken it apart nearly 4 times trying to figure this out, someone please help me. it does back fire but just barely
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 08-22-2011, 07:35 PM
2002 Chrysler Sebring
My Garage
Make sure that the #1 cylinder is at TDC on the COMPRESSION stroke. Remember that the crankshaft goes around twice for every rotation of the distributor.
There may be a raised "1" at the terminal on the cap for the #1 cylinder wire. It may be on the old cap if not on the new one. The rotor should point toward that terminal.
Old 08-22-2011, 07:56 PM
helo735's Avatar
This is the best thing I could find, I assume the 96-99 2.5L V6 is the same.
Old 08-22-2011, 08:35 PM
when i set it on TDC the rotor was sitting at number one on the cap, i probby need to do this again this care just been a nightmare for me
Old 08-22-2011, 08:43 PM
helo735's Avatar
The only thing I can say is to just check and double and triple check your wires...where they're going, and where they're hooked up to. Don't be afraid to take a break for a few, fresh eyes are better than tired and frustrated ones. TRUST me. For instance...
I had a coil crap out on a GM 3800 V6. No big deal.
Replaced the coil, and was having all sorts of terrible problems with back firing and preignition...sometimes it was stalling so hard it was chirping the serpentine belt. I fought with it for the better part of 4 hours, checking plugs, checking spark, etc. and finally concluded that I'd somehow caused the timing chain to skip a tooth during one of the times it had stalled. I went inside, chilled for a bit, came back out, and noticed within 5 minutes that I'd swapped two wires on the coilpack. I corrected them, and the car ran great.
I wish you luck, and don't give up. It's just a machine.
__________________
~Aaron
1998 Chrysler Sebring LXi - 2.5L V6 - 233k miles
"Then I saw that there was a way to Hell, even from the gates of Heaven..."
Tags
2000, 25, 25l, 96, chrysler, compression, distributor, fire, marks, plug, sebreng, sebring, stroke, timing, v6
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
