Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 10-19-2011, 10:34 AM
Default 98 Sebring, Spark & fuel, wont start
98 Sebring Conv. 2.5- I wash the car in the driveway, finished, pulled it into the street with no problem. Went to start it about an hour later, wouldn't start and ran down the battery. I pulled my truck over and jumped it and after a while got it started. It ran real rough when I gave it some gas and ran fine at idle. Pulled the jumpers off moved the truck out of the way and went to move the car, as soon as I put it in gear it stalled and hasn't started since. After getting it in the driveway I went to work on it.
First I had no spark, replaced the crank position sensor (had problems about 3 week ago with it) still no spark. I put a code reader on it and gave a code for the cam position sensor. Replaced the distributor with the cam sensor built into it. Replaced the throttle position sensor.
Now I have spark (on the front 3 cylinders) checked them by pulling the plugs and with the wires on them and grounded them (when the plugs were pulled they were wet with fuel), pulled the fuel line off and cranked it, got fuel. Pulled the timing covers and checked the timing which is dead on, swapped the emergency shut down relay with a good one, swapped the fuel pump relay with a good one and checked all the fuses.
I also tried it with starting fluid in the intake and in the cylinders.
What else can I check!!! This is driving me NUTS!!!
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 10-19-2011, 07:10 PM
Did I mention this is my wifes car and she's driving MY truck!!!
PLEASE HELP
Old 10-19-2011, 08:09 PM
2002 Chrysler Sebring
My Garage
any codes?
Old 10-19-2011, 08:14 PM
The only codes I got were for the cam and crankshaft position sensors. Both were replaced.
Old 10-20-2011, 09:40 PM
My Garage
So no codes now?
If you have both spark and fuel, it should start. What kind of fuel pressure do you have? If it's just dribbling out, it may not be enough. Should be something like 55 psi to be effective.
Tags
1996, 98, chrysler, crank, fuel, position, psotion, sebring, sensor, sensors, spark, start, throttle, wont, zebring
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
