Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 11-08-2011, 10:43 AM
Angry 99 sebring jx conv won't charge
The battery light started coming on in my 99 Sebring jx. had the alternator bench tested and battery tested. 2-yr old battery tests fine, alt was putting out 11.5 volts. Replaced alternator with a used alternator, no change in problem. Checked ground to engine, and continuity of heavy charging wire from alt to remote positive battery post....all good. Installed a conversion kit that uses an external Chrysler voltage regulator to cut the PCM out of the equation....no change. (Kit came with new wiring harness with new field wires). Voltage in field wires is 12.59 and 0.235, respectively. Had the replacement alternator bench tested, it puts out 125 amps. I am at wit's end. What am I missing? With the PCM out of the equation I can find no reason for this. At idle the battery charges slowly in .01 volt increments....under load or RPM's above idle battery voltage slowly drops.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 11-08-2011, 05:18 PM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
with all things equal in the matter u either tested something wrong or not looking at correct wires or something like that.
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 11-14-2011, 11:15 AM
Default problem found
The problem was the harmonic balancer. While the outer ring of the balancer WAS spinning, it was spinning at a slower speed than the inner hub, thus not turning the alternator fast enough. I placed a new belt on the alternator, left the power steering belt off to test the alternator. Within one minute the outer ring of the balancer separated from the inner hub of the balancer.
Tags
00, 99, access, alternator, battery, charge, chrysler, external, jx, light, regulator, remanufactured, sebring, voltage, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
