Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 08-18-2011, 08:58 PM
Default Alot of heat under dash
Just recently the Sebring has ALOT of heat coming from under the dash. The car is not overheating, but man is that heat brutal on my legs while driving. I can also feel heat in the middle console arm rest...
Any idea what it could be?
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 08-19-2011, 08:20 AM
2002 Chrysler Sebring
My Garage
1) What model Sebring is it?
2) Do you have automatic temperature control?
3) Have you set the heater controls properly?
Old 08-20-2011, 10:16 PM
helo735's Avatar
sounds like the cat is getting hot. SES light on?
Old 08-21-2011, 06:29 AM
2001 Sebring...just a standard..
Heater Controls? There is no automatic temp control.
Old 08-21-2011, 06:30 AM
Cat? As in Catalac Converter? SES light? There are no lights on.
Old 08-21-2011, 02:23 PM
My Garage
"Have you set the heater controls properly?"
That was a question. "There is no automatic temperature control" does not answer the question.
Old 08-21-2011, 08:01 PM
helo735's Avatar
In all reality, to show that I'm not a complete troll...
Does it seem like there is a fan blowing the heat on your legs? What happens when you adjust the heater controls? Have you changed the HVAC settings?
It sounds (at least to me) like the HVAC is blowing hot air on your legs through the floor registers. If everything is set correctly, then something within the HVAC could be messed up.
Old 08-21-2011, 08:02 PM
helo735's Avatar
Since I apparently can't edit posts, try also to turn your A/C on, and see how that affects it.
Old 08-22-2011, 08:37 PM
just had similar problem - very hot engine compartment and engine temperature guage show middle of scale. Check EGR valve - seal it off if it helps change EGR valve.
Old 08-22-2011, 08:46 PM
helo735's Avatar
That wouldn't explain how the heat is getting through to the passenger compartment though.
I'm still leaning toward something being fuxored with the HVAC system, with it being stuck on heat or something.
Op, if you have the setting on the heater controls, try swapping it to Recirc instead of fresh air. See if that helps at all.
__________________
~Aaron
1998 Chrysler Sebring LXi - 2.5L V6 - 233k miles
"Then I saw that there was a way to Hell, even from the gates of Heaven..."
Tags
2002, alot, car, chrysler, comimg, coming, control, dash, driving, heat, heater, hot, jeat, registers, sebring, valve
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
