PLEASE HELP QUICK
PLEASE HELP QUICK
I currently have a 97 chrysler sebring convertable V6 2.5. I just drove it and I parked for a while went to go and start it and with no luck it didn't start. I hooked a computer up to it and it said no signal to PCM what happened and what can I do to fix it if someone could please help me with this.
RE: PLEASE HELP QUICK
first find out if u have commucation with any other computer in the car and if yes then u have a bad pcm or wireing to the pcm. IF no commucation with any other computer then something it taking down the bus or the pcm is taking down the bus.
U wont be able to talk to any other computer unless u take it to the dealer or some one that has an expensive scanner.
I hooked it up and it does work with everything else on the car it just error. The scanner is an expensive one its a snap on on that costs like $7000 also I disconnected the wires to the distrubetor cap and I wasn't getting any voltage. What would make that go out like that all of a sudden? Also sorry about the spelling.
Now I have one thing my check engine light always came on but I know it was because of the O2 sensor. Now while I was checking the fuses I wasn't getting any power from the fuse on both contacts but I know the fuse is good would that have something to do with it. Also where is the PCM located on the car? There is so many thing that looks like the computer but I don't know. Thanks for your fast response.
I am sorry from what the scanner said it read NO CRANK REFERANCE SIGNAL AT PCM if you have any Idea's it would be greatly appreciated I am going to try and take off the crank sensor and clean it to see if it works. Since I am in the military stationed overseas it takes about a week to get parts here wish me luck.
If you join eautorepair.net, it will give you the location of everything for your engine, Sensors, splices, connectors, test points etc etc .... pretty good buy .. Lemme look for the crank shaft sensor for ya ....
