Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
Search
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 03-15-2008, 04:02 PM
Default Code P0456 Very slight Evap Leak
Bought 2002 Sebering Convertible 2.7 V6. About 5 weeks latercheck engine light on. Took it to mechainic. The code is P0456 very slight evap leak. Tightened up Gas Cap. Two days later check engine light is on again. Took it back to the mechanic replaced the gas cap. If that doesn't fix the problem he said I may have to take it to dealership. He said he does not have a smoke test machine.Two days later check engine light on. Any suggestions to the problems that are typical to thiscode.Any ideas on what are the parts, hosesthat are the typicalculprits.
Bob
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 03-15-2008, 05:21 PM
moe moe is offline
Default RE: Code P0456 Very slight Evap Leak
look for cracked rubber line under the hood leading back to the fuel tank.moe
__________________
25 or so years exp.with chrysler,plymouth,dodge.jeep."A"tech at dodge /jeep dealership.living in N.J. "LET ME KNOW MOE!!
Old 04-05-2008, 09:27 AM
Your evap (charcoal) cannister, duty cycle purge solenoid, and related vacuum hoses are suspect.
__________________
Fellow Chrysler Owner
Old 04-05-2008, 12:52 PM
Thank you Moe and irdaneel for the information on the possible repairs to the questionposted 3-15-2008. I check under the hood and removed the air cleaner box assembly, but did not notice any problem. Since I am at a condo complex I could not get any more involve because of the rules relating to working on your car. I took the car to a Gulf Cost Dodge dealer in Ft. Myers,FL where they preformed a smoke test and discover a split hose. They charged $99 for the investigation and test and $8.00 for the hose. I was made aware of the $99 before the testing when I took the car in, but what was one to do. Luckily it was only the hose. They even said if the code reoccurs with in a couple of months that they would waive the $99 fee.
This form is very helpful and I appreciate the help that both of you provided.
Snowbird2006
Old 10-15-2010, 12:45 PM
Smile Awesome
I have a Town and Country mini van that gave the same code. Could you tell me about where the tube was located please?
Old 05-16-2013, 02:17 PM
Default P0456 Fault code
Hey Bob, I have the same problem on a 2002 Sebring Lxi Sedan. Replaced gas cap and some split hosing between the gas tank and evap. canister. Light still on. I'm having it smoke tested tomorrow, there are some hoses on the top of the gas tank that are vulnerable to cracking with age, could be the evap canister leaking or faulty solenoid valve.
What was the fix for your issue?
Old 05-16-2013, 02:19 PM
Duh, sorry Bob, just read your post. Hope mine is just a split hose too!
Old 05-16-2013, 05:41 PM
2002 Chrysler Sebring
My Garage
Did you clear the code after replacing the split hose? If you did not clear the code, it may take a few driving cycles for the light to turn itself off.
Tags
0456, 300m, check, chrysler, code, codes, cruiser, engine, evap, leak, p0456, pacifica, pt, sebring, voyager
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
