Condenser Replacement is giving me FITS!!!
Old 06-28-2013, 10:34 AM
brad4567's Avatar
Default Condenser Replacement is giving me FITS!!!
I am working on a 2002 chrysler sebring sedan 2.7L V6. I have ordered several different replacment condensers both aftermarket and oem. Obviously something has interchanged since 2002. The original condenser has a block fitting on the driver side that connects an a/c line and a bolt hole. It also has an a/c line that runs across the top of the condenser to the passenger side. All of the replacement condensers that I have ordered have only one block that is on the driver side that has two a/c line holes and a bolt hole. WHAT THE CRAP DO I DO!!!
Old 06-28-2013, 11:43 AM
Make sure they are not sending you parts for a coupe. The coupes were built by Mitsubishi and are totally different automobiles.
The sedan parts should be compatible with convertibles and Dodge Stratus sedans.
Old 07-01-2013, 09:49 AM
brad4567's Avatar
Default Finally resolved
I ordered seven different condensers for this particular vehicle. 3 a/m SEDAN condensers, an o'reilly condenser, a coupe condenser (just to prove a point) and a chrysler condenser. Finally on the 7th try I got the correct one, but only because I used a recycled condenser. Every condenser sent to use on a sedan looked the same except for the O'reilly. On to the next headache!!
Kaysvan
14
05-30-2013 09:33 AM
dskompress24
11-21-2009 03:36 PM
cserbantez
07-18-2009 02:54 PM
Danygirl128
03-06-2007 04:55 PM
froggyscike
12-14-2006 02:36 AM
Quick Reply: Condenser Replacement is giving me FITS!!!
