crank but no start 2004 sebring 2.7
Old 12-11-2013, 06:42 PM
johnkraus's Avatar
Default crank but no start 2004 sebring 2.7
changed oil pump put back together engine cranks but will not start.no spark at plugs.spins fast but no start.unpluged cam sensor and it starts.turned it off plugged in sensor and it would even try to start!
Old 12-11-2013, 11:09 PM
u installed the wrong cam tone wheel mmmm u get to take it back apart and put the old cam tone wheel b
Old 12-12-2013, 07:17 AM
johnkraus's Avatar
didnot change tone wheel .Took it off to get slack in chain to remove crank gear and remove oil pump,put same gear (tone wheel) on.is it possible to damage it?
Old 12-12-2013, 08:24 AM
johnkraus's Avatar
didnot change gear(tone wheel). took it off to get slack in chain to remove crank gear and remove oil pump,put same gear (tone wheel)on.is it possable to damage it.
Old 12-13-2013, 04:15 AM
gb1994's Avatar
Please read-out the error code (3 times ignition off and on, then turn it on and wait for the codes). That helps to define what your problem is.
4UHoney
04-22-2021 01:32 AM
eriemon
12-16-2013 09:31 AM
melissabraggs
04-30-2011 05:53 PM
melissabraggs
04-30-2011 05:48 PM
jaycarr
09-08-2009 08:49 PM
Quick Reply: crank but no start 2004 sebring 2.7
