driver window
window
follow up question.....how do you remove the window switch panel? there is a screw under the hand grip and 2 screws under an access tab in the hand grip area, but upon removal, it still won't let go. any help? thanks
Not sure about your '08, but the usual thing for access to the switch panel is to remove the entire door trim panel. Get yourself a set of plastic trim tools before you tackle that job. They're cheap and worth their weight in gold. You might want to think about investing in a shop manual. Then you can read up before you start a repair job and then you can decide if you and your toolbox are up to the task.
davet
08-11-2007 04:17 PM
