Electrical short
Old 02-05-2007, 08:48 PM
embalmer41's Avatar
Default Electrical short
I have a 2000 Chrysler Sebring LX, 2.5L and the ignition switch fuse keeps blowing. My wife was driving to work and the car just quit on her. I thought it was a bad battery cable and i cleaned it up and nothing happened. So i looked in the engine bay fuse compartment and saw the blown ignition fuse. Replaced it and it blew righ away. Had it towed to the shop and the mechanic put a fuse in it and it cranked right up. Got the car home and parked it and went to crank it the next morning and the fuse blew again. When it blows i loose dash lights and everything. But i noticed when you put the key in the ignition and turn it to run the dash lights come on and you you can tell something is drawing a lot of power because the lights start to dim and then the fuse blows. Can anyone point me in the right direction as to where i should start looking. Been to two mechanics and they can't find anything wrong. It always cranks at the shop and they can't find what's wrong unless they can duplicate it. Thanks in advance. The fuse it blows is the 30A ingnition switch fuse.
Old 02-05-2007, 08:56 PM
Default RE: Electrical short
convertable or 4 door???
all i can give u is the computers or what ever is tied into that cicuit let me know what kinda car u have.
Old 02-05-2007, 09:12 PM
embalmer41's Avatar
It's a 2000 Chrysler Sebring LX 2-door coupe. Thanks
Old 02-05-2007, 11:30 PM
wow u had to have one of the bigest pain in the *** cars ever made for electrical.
give me your email so i can mail ya some pdf with the wire diagrams u have several things that can short out and if its not doing it right now hehe carry a few fuses then. Send it in a Private message
Old 04-21-2007, 10:20 AM
embalmer41's Avatar
Well , i finally got around to checking the electrical short problem and i think i've traced it to the ETACS-ECU. I;ll be removing it on Sunday and see what the problem is or if i can find one if that is the problem. Has anyone ever removed one of these and if so is it difficult? Thanks.
Old 04-21-2007, 10:46 AM
9 times out of 10 computers are not the cause of shorts
Old 05-27-2007, 10:08 AM
embalmer41's Avatar
Well' I finally foumd out tje cause of the electrical short. It was the ignition switch itself. Put the new one and she fired right up. Just to be on the safe side, i put the old one in to be sure it was the problem and the fuse blew right away. Thanks for the help.
Old 07-07-2007, 02:13 PM
I have a 2001 Chrysler Sebring LX (Canada) that is doing the same thing? Have you solved the problem...Any help you could give would be great?
Old 07-07-2007, 03:39 PM
2001 Chrysler Sebring LX (Canada) blowing ignition fuse on start up..Any ideas?
Old 07-07-2007, 03:51 PM
read the post by enbalmer41 right above u
bsparks
09-19-2013 07:26 AM
ymitchell
04-29-2009 09:36 PM
Pause
01-29-2009 09:04 AM
cvchrysler
01-03-2009 08:56 PM
lthom49086
03-05-2008 08:35 PM
Quick Reply: Electrical short
