firing problem
Old 04-16-2015, 07:24 PM
capt. joe's Avatar
Default firing problem
Hi I currently just bought a 2000 Chrysler Sebring convertible was checking everything over as I was messing around pulled spark plug wire off . before I cld put it back the car shut off will not crank now it turns over but will not crank and run . any help or suggestions I've read about the ASD relay but only seen a 20 amp fuse . thanks in advance . the fuse is good
Old 04-16-2015, 07:25 PM
Codes?
Old 04-16-2015, 07:33 PM
capt. joe's Avatar
No codes no spark
Old 04-16-2015, 07:37 PM
capt. joe's Avatar
The car was running perfect . pulled the plug wire before I cld get it back on the car shut off .
Old 04-17-2015, 04:21 PM
I got that part. Have you made any efforts to get fault codes out of the computer?
And why would you pull a spark plug wire out while the engine is running?
capt. joe
04-16-2015 07:31 PM
christopher123
Cirrus & Breeze
01-15-2009 12:26 AM
tiredmom888
10-20-2008 05:15 PM
musicfreak2195
09-19-2008 12:47 AM
04-25-2005 10:35 PM
Quick Reply: firing problem
