Head gasket job
Ok just got back from a qualified machine shop, heads are OK. No warp, valves are OK too . I checked the block as TNtech advised. It is OK too .
I cleaned the heads with solvent and pressurised air. Now waiting for Head gaskets from dealer.
Old gaskets were not blown, but there were traces of minor combustion leak from cylinder 2 to cylinder 4 and leak from cylinder 4 to water jacket.
I appreciate any idea that helps me identify the real problem behind this leak.
#15
It won't come back out until there's oil pressure pushing it out, meaning the engine must be running. Be prepared for quite a bit of valve train noise when you first start the engine. It should quiet down after a few seconds.
#18
I've got a 2001 Convertible with 125,000 miles. Have had no problems and it has been running great however I checked the oil a few days ago and found it to be milky. Should I consider head gaskets or replacing the engine? I could do the engine swap myself but the head gasket job I would have to pay someone to do.
#20
re:Waterpump
Well I have not driven it at all but not being much of a mechanic that would be great news if its just the water pump. I really appreciate the answer. Wish you lived near Cincinnati I would pay you to do it!
