Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 09-05-2011, 02:58 PM
Default Interior blower not working
I have a 2002 Sebring Convertible LXI with a 2.7 engine. My interior blower stopped working on a hot day. I checked all fuses but none are blown. Is there a fusible link off the starter? I have back problems and would rather not crawl under the car if I do not have to. Thanks in advance. Scott
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 09-05-2011, 03:34 PM
2002 Chrysler Sebring
My Garage
Check the resistor block. It's under the dash. It's an easy repair for somebody without a bad back. You remove the panel below the glove box and remove a screw or two to pull the resistor. The replacement requires opening up the hole a bit with a file. Parts stores may have a replacement part; if not, the dealer can get it for you.
Old 09-05-2011, 04:49 PM
Thank You dcotter0579, I will check it tomorrow since it's raining. I had anouther vehicle that the blower resistor went and I still had high blower function. The blower doesn't work in any position. Low, Med, Or High. Do you think it is still the resisto? Thanks, Scott
Old 09-05-2011, 08:43 PM
My Garage
You can check the resistor for continuity easily if you pop it out.
Could be the control head. That's very easy to pull out. Grab the trim bezel with your fingers at the bottom edge and pull straight back. It will pop loose. Then use a plastic trim tool or wooden paint stirrer to pry it off. Reach around the back of it once it's loose and unplug the connections.
They come up for sale on eBay every once in a while, or scout your local junkyard. The same part was used on Sebrings from '01 to '06 and Dodge Stealths too, so there are lots of them around.
Could also be a shot blower motor. It's a PITA to get out.
Tags
2002, blower, chrysler, chysler, fan, fuse, heater, location, low, quit, sebring, speed, speeds, stopped, work, working
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
