need advice for possible trans flush/drain&refill
Old 02-08-2014, 05:08 PM
zach92's Avatar
Default need advice for possible trans flush/drain&refill
Greetings,
this is my first post to CF but ill try to be as thurough as possible.
Car: 01' Sebring coupe lxi 3.0L, auto trans 160k miles
I was topping off fluids after finishing an oil change this morning and i noticed my trans. dip stick was bone dry so i went ahead an added about 3/4 QT of B&M trick shift fluid that i had left over from my previous car. as it turns out that was a bad idea...The car at first would not even shift into any gear outside of park, so i waited 20 mins and tried again and this time after revving to about 4 grand a few times it SLAMMED into reverse and then after trying to slip into drive for a minute or so it SLAMMED into drive. i tried to go for a short drive but quickly turned around and parked it after it slipped out of drive and SLAMMED back in about 6 times in a minute. Now after reading up on my stupid mistake all day ive realized that this car only takes ATF+4 and Trick Shift is +7. So my question is If i drain the fluid from the pan, clean it out and refill with correct fluid will this fix the problem? or is it a much bigger issue? also ive heard that flushing could do more harm than good but in my case is it worth it to go ahead and try a full flush?
worth mentioning i am on an EXTREMELY tight budget so my only option is doing all the necessary work myself.
Any help at all would be greatly greatly appreciated! thanks
Old 02-09-2014, 05:54 AM
FIREM's Avatar
Agreed ATF+4 is the ticket but a "bone dry" dipstick is not good.
I doubt 3/4 qt of the wrong fluid is the cause of the problems described.
Pan drop and filter change will get 60 -70 % of the fluid. I disconnect the trans cooler lines and using low pressure air force as much fluid out as I can. This gets 80-90% of the fluid out.
Walmart usually has real ATF+4 for the best price around 4 per qt.
Old 02-09-2014, 07:55 AM
zach92's Avatar
Thanks for the reply. The only reason im assuming the problem is from wrong fluid is because ive never had a trans problem before and this problem occured immediately after putting in the b&m. Hopefully its not a bad sensor! If it is ill be posting again for advice on changing that. I picked up ATF+4 and rtv lastnight.
Ill keep posted if the pan drop and line blow fixes it.
Thanks again
palafoja
09-01-2011 09:08 AM
Illbay
07-04-2011 09:47 AM
dcotter0579
03-17-2011 02:36 PM
parlayjay
04-18-2010 03:28 AM
bacalao
05-15-2008 09:51 AM
Quick Reply: need advice for possible trans flush/drain&refill
