Headlight wire
Headlight wire
Hello ladies and gents,
I attempted to change the headlight on my wife's 2011 Chrysler 200 and found the wire to burnt out. I've attached a photo for reference. Is this wire replaceable or do I have to replace the whole headlight piece? I'm asking here because I don't want to take apart the whole front end unless I have to. Thanks in advance for the help.
What you need is the connector, not the wire. The wire is part of an entire harness which is very expensive and hard to install. You may be able to just buy the connector at the dealership but your best bet is probably to go to a U-Pick-It type junkyard and cut off a connector with enough wire to splice it onto the old wire. When splicing it on, use some shrink tubing and tape to get a good sealed connection.
RedRumRick
02-27-2019 05:05 PM
