Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Sebring
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 12-18-2011, 07:52 PM
Default power steering problem, HELP!!!
hey everyone, i need a little help i have a 04 sebring 2.7l sedan and my motor went bad. so i got another one from work and i took all my parts off the one motor and put them on the new motor. so i know everything was good. the problem is when i got the motor in i started the car and tried to drive it and the power steering is hard to turn, and every now and then you have a easy spot like it is working but then goes right back to being hard. any ideas on what this could be. any help would be great, thanks
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 12-18-2011, 08:11 PM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
go back and take a look at your work first of all.
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 12-18-2011, 08:16 PM
already did a couple of times, it has fluid, the belt is tight, i have no leaks. what else should i check
Old 12-18-2011, 08:59 PM
2002 Chrysler Sebring
My Garage
There was a guy on here a couple of weeks ago whose harmonic balancer went bad, resulting in no charging for his alternator. I would think that if yours is failing, it might result in problems driving the power steering too. When yours is acting up, see if you can observe the belt movement. If it's jerky, that might be your problem.
Old 12-18-2011, 09:51 PM
i already tried that to, i had my buddy in the car while i raised it up on the lift and i watched the belt to make sure everything looked good there to and it did. belt and pulleys was working just fine nothing jerky at all
Old 12-19-2011, 10:32 AM
My Garage
If the pump is being turned properly by the belt there are some remaining possibilities. The pump has an internal flow control valve that is designed to relieve excessive pressure, for instance when the wheels are turned all the way to the side. That valve could have gone bad. Or you could have internal leakage in the steering gear. Or you could have a kinked hose, or a bad hose that restricts flow for some reason.
The only thing you can easily rule out is a kinked hose, which should be able to be found on visual inspection. The other things involve expensive parts with invisible problems.
Hooking the system up to a flow analyzer might narrow the source of the problem, but will involve the use of expensive equipment and a trip to either the dealer or a specialized service facility with the right gear and knowledge to use it.
Tags
2000, alternator, chrysler, crystler, failed, failure, jerky, leak, power, problem, problems, seabring, sebring, stearing, steering
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
