I have a 07 Sebring, the insturment cluster lights are not working. I have put in a new multi function switch. I cannot find a fuse that would help solve this problem. Any advice?
thanks in advance.
thom
Hi, there was a guy in western Canada ( Mr. Wizzard something) that fixed indigo dash lights in sebrings and many other brands. He turns them around same day he revives them. I can't find his info but he fixed mine very fast, a diode replacement if I remember.
I have same trouble with my Sebring 2007, called authorised service and they told it's well known issue with this kind of backlight, factory is not selling these luminous elements separately therefore they can replace whole dash, which is extremely expensive. I'm looking for any repair tips as mine is working fine most of the time, it goes out or flicker maybe once a week.
I did some research on this- Chrysler is using EL panels/strips called Indiglo. Most common problem is inverter from 12 vdc to approx 120 vac to power this EL. Here is similar story : New gauges, now installed!! - Stratusphere
I'm about to take apart my dashboard and check out the inverter and replacement options.
