Hey guys have a trans problem on a 2001 chrysler sebring 2.7 eng trans will not shift out of low 1 (have to pull over turn car off restart sometimes trans will shift after that have a 0700 code &0605 code any advice would be helpfull!!!!! trans does not slip,trans fliud full,was thinking it could be trans control module THANK,s JAMES EAGAN
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep KKeller608@aol.com http://kevinsmobilerepair.com
I might as well give up this gig its like talking to brick walls here most of the time. Do i not have any pull around here being a Chrysler tech for 15 years?
Symptom:
P0605-INTERNAL TCM
POSSIBLE CAUSES
TCM - INTERNAL ERROR
TEST ACTION APPLICABILITY
1 If there are no possible causes remaining, view repair. All
Repair
Replace the TCM. WITH THE DRBIIIt PERFORM QUICK
LEARN AND REPROGRAM PINION FACTOR.
Perform 41TE TRANSMISSION VERIFICATION TEST - VER 1.
__________________
