It's likely that the wheels on the 300 are a bit wider than those on your Sebring. As for installing the bigger tires on your Sebring, I'd be very cautious as the wheel well clearance on the Sebring is very tight.
If you've got the tools and lots of time on your hands you can check the clearance by removing the spring and putting the suspension and steering through its full range of travel.
Thank you for the reply,I suspected it wouldn't be plain sailing
Would it then be possible to use 235/50/18 Tyres?
The size I'm currently using are extortionate, the other sizes while expensive are half the price of the 215/55/18.
To make matters worse I only got eight thousand miles out of my last Tyres from new,I simply can't afford that sort of outlay every eight thousand miles.
I asked the Tyre specialist if the tracking was off and he said, 'No it's evenly worn right across the Tyre, it's just wear and tear'
I must stress,this isn't the guy I just bought the new ones from, I got them online as he doesn't even stock that size, he was only fitting them for me so had nothing to gain by not telling me the truth.
