Sponsored by:
Sponsored by:
2.5 CRD cutting out on idle the story cont
Old 02-27-2014, 03:18 PM
richjones19772000's Avatar
Default 2.5 CRD cutting out on idle the story cont
Still no further on with this issue. So far these components have tried.
Mass air flow sensor
Crank sensor
EGR valve (cleaned)
Inner fuel tank filter
Outer fuel tank filter ( the one with all the housing and pipes)
Tomorrow and EGR valve will be tried.
If this doesn't work then god knows!!!
Old 02-27-2014, 04:09 PM
tfb's Avatar
tfb
tfb is offline
key dance for fault codes?
Regards
Richard
Old 02-28-2014, 04:41 AM
Regards
Richard
Hi , tried that came up with a code for Mass airflow sensor, which has been changed
Old 02-28-2014, 05:10 AM
tfb's Avatar
tfb
tfb is offline
is the fault code still present?
If so, you need to be aware that if it is reporting an unexpected value from the MAF then it may not be the MAF.
The ECU knows how much air should be coming through the MAF given the level of boost, engine revs and load etc. An air leak in the intake system can cause the MAF to give a reading the ECU doesn't like, in addition the wiring and connectors need to be checked
Regards
Richard
Old 02-28-2014, 02:20 PM
Crank sensor goes with cam sensor. Then theirs fuel rail valve. But Mass sensor comes up. Tfb says it all.
lentec
15
11-13-2021 08:12 AM
Jac Borthwick
04-10-2014 09:55 PM
richjones19772000
02-05-2014 04:29 AM
joker2cv
20
07-26-2012 11:32 AM
herSpuptupsep
04-01-2009 09:12 PM
Quick Reply: 2.5 CRD cutting out on idle the story cont
