2.5 crd showing fault codes: 100.5, 100.4
Old 12-11-2012, 11:20 AM
strongarm9001's Avatar
Angry 2.5 crd showing fault codes: 100.5, 100.4
The speedometer in my 2002 Grand Voyager 2.5crd suddenly stopped working just stayed at 0, sometime when driving it moves to 60 and the drops to 0. All other gauges seem to be working fine.
the two fault codes i am getting are: 1005, 1004. I have changed the speed sencor and cluster but this did not help. please help to say whats the promlem.
ANOTHER PROMLEM IS THE Glow plugs only get power for a secon and this is causing loads of promlems on cold morning, I have changed the glow plugs in this case, but this did not help.
Last request, dose anyone have a cd or manual for the 2.5 crd 2002 uk module?
Please help
Gerald
Want to determine if it could be something minor that I could fix myself before going to the dealer and handing over my first born.
Old 12-11-2012, 02:19 PM
Raptor 07's Avatar
Disconnect the negative battery cable and disconnect the connections on the Transmission Control Module (TCM) and the Powertrain Control Module (PCM). Look for any signs of corrosion and bent or pushed pins. On US spec (Left hand drive) vans they are mounted behind the driver's headlight. Remove the driver's front tire and pull back the wheel well liner for access. Next, give your first born a going away party.
Old 12-11-2012, 02:20 PM
tfb's Avatar
tfb
tfb is offline
I've found this Russian site with a lot of info on the European models
Index of /pub/chrysler-dodge/manuals
or you can pay £25ish for one days access to Chrysler's techauthority website and they have all the manuals and wiring diagrams.
Regards
TFB
Jfizzle
02-22-2020 04:37 PM
Daniel Williamson
03-02-2015 02:29 PM
Virglijus
05-20-2014 02:30 PM
stewartsoftware
04-17-2011 03:22 PM
creepycarrie
Other
12-12-2005 03:27 PM
Quick Reply: 2.5 crd showing fault codes: 100.5, 100.4
