Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Voyager & Town & Country
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 12-14-2011, 05:33 PM
Default 2001 t &c headlamp
2001T&C. Left low beam Inop. Bulb is good, 12v to socket, continuity w/ground.
I'm at a loss. My wife said hi beams worked yesterday, but not today.
Swapped start relay w/ accessory relay, no luck.
Any ideas out there? Thanks.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 12-14-2011, 06:28 PM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
if u have 12v and ground it will work use the bulb from the other headlight see if it works.
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 12-14-2011, 08:27 PM
Kevin: Thanks for the quick response. I see you have been very helpful in this forum.
I took both bulbs out from each side. Both sockets have identical volts, resistance and ground. Both bulbs work on the right side. I don't understand how I can have volts and ground, but neither bulb will work on the left!
Thanks, Jim.
Old 12-14-2011, 09:59 PM
Had to get the simple stuff out of the way first keep it KISS
Get the volt meter out again turn on the lights and tell me what wires have 12v and ground then turn on the high beams and tell me the same.
__________________
KKeller608@aol.com
Old 12-16-2011, 10:38 AM
Okay, Kevin:
Both sides work normally in high beam. (I earlier mis-diagnosed because I didn't have the key turned!) The left side high beam also comes on when the turn indicator is held to the high beam flash position, but the left side low beam will not ever come on when normally selected. The high beam blue light on the dash does come on, the right side works normally, and the bulb out yellow caution light comes on.
Volts and ground are identical to both left and right headlight sockets. Volts are as follows, oriented to the socket connector pin on top:
Lamp off: left = .78v, right .48v
Lamp on dim: left = .78v, right = 12v
Lamp on bright: left = 11.75v, right = .5v.
Ground from center pin: Lamp off: .2ohm, Lamp on: .2ohm
So I think the switch is working since the voltages swap sides, and I'm thinking the ground is good. The bulb is good, as I've swapped both sides.
You're a hero if you can explain this one to me!
Thanks, Jim.
Old 12-16-2011, 08:36 PM
u have a IPM or a front controller issue the IPM is he fuse box itself
__________________
KKeller608@aol.com
Old 12-19-2011, 09:33 PM
Kevin: Is there anything else I can do myself, or is it time to take it in?
Thanks, Jim.
Old 12-19-2011, 11:51 PM
u can replace an ipm or front controller there is nothing to program
If u get me the part number off the 2 I might have ones I will sell cheap to ya.
__________________
KKeller608@aol.com
Old 12-20-2011, 12:09 PM
OK,Kevin, how much for a fwd controller?
-Jim
Old 12-20-2011, 04:30 PM
as I said i need the number off the old one to see if the one I have will even work
__________________
KKeller608@aol.com
Tags
04869000aj, 2001, 38, beam, country, dodge, headlamp, headlight, high, ipm, lamp, low, pin, town, work
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
