2002 Town &Country blower fan
RE: 2002 Town &Country blower fan
Yes, sort of. If you have the automatic temperature control (where you set the temperature digitally), then you don't have a blower resistor but something called a "blower control module". It doesn't contain resistors-- it has electronics that receive digital commands from the control head and then quickly cycles the power on and off to control fan speed. I've had two of them die on my van-- one died with the fan on high (even if the climate control is turned off) and the other died with the fan off.
The main difference from your perspective is that it's a lot more expensive than a resistor block-- I paid about $70. Fortunately it's easy to replace though. Just open and empty the glove box, squeeze the sides together and let it hang down. You'll see two connectors going into the HVAC box-- take the connectors off, then use a phillips screwdriver to remove the two screws that hold the control module in place. Put the new one in and you're done.
Brian24
03-07-2014 03:49 PM
nickw23
08-26-2012 03:46 PM
colbertgang
04-26-2009 09:30 PM
300winchester
03-29-2009 02:48 PM
