2002 Town and Country Fan problem
Most def. blower resistor..I just replaced mine and everything works fine..Disconnect neg.(black) terminal on battery, empty glovebox push sides of glovebox in and glovebox swings down. The resistor is right in front of you..Disconnect the 2 harnesswires, then 2 screws and slide new one in, plug in and done. I got mine at O'Reilly Auto Parts for $14.00..Good Luck!!
Philip
Mr. Keller,
Can you please tell me how to get access to the fan and clean the trash out...I tried taking the bottom of the blower motor housing off, but because of access restraints I stopped. Can you point in a different direction or some instructions for a simpler task..Thank you for your help!!
