Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Voyager & Town & Country
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 10-13-2011, 08:46 PM
Default 2005 T&C, 3.8L Ignition Mystery....
What happens:
When starting the engine it will crank for some time before ignition happens. Once this happens, quite often, it will have an flooding type odor.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 10-13-2011, 08:57 PM
My apologies, for some reason my first entry happened without my completion - unknown cause ... just like my mystery.
Continuing from above ....
One issue that I know of:
The fuel tank will need to be replaced due to a broken vacuum line nipple that is permanently installed in the fuel tank. Thus I currently have an open system. The Chrysler dealer mechanic stated this as being a vacuum pump ... I am uncertain that this is the correct labeling of the part. This originally was a splashback issue.
What I have done about the starting issue:
Installed the following - Crank and Cam Shaft Position Sensors, Spark Plugs, Spark Plug Wire Set, Air Temp Sensor, EGR Valve, Both O2 Sensors, and a Starter Relay.
Everything that was done gave me about 2 to 4 perfect starts, then I was back to my original issue.
What I am trying to decide:
Should I install a Throttle Position Sensor, an Idle Air Control Valve, a PCV Valve, a MAP sensor, or and Ignition Coil?
The starter appears to do its job.
I am getting desperate about this issue. Could this be related to the fuel tank vacuum issue? I have been thinking that something is not telling the spark plugs to do their job until there is plenty of fuel there.
Ideas and thoughts would be appreciated immensely.
Old 10-13-2011, 09:39 PM
One more thing:
I of course have been getting a P0456 code for the major evap issue. I also get a P0303 code, but only after start up. Not any other time will it show its ugly head. Once again, I just replaced the spark plugs and wires and erased the code.
Tags
2005, 38, 38l, chrysler, ignition, system
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
