Sponsored by:
Sponsored by:
2005 T&C turn signal/brake light out?
Old 01-24-2011, 07:50 PM
oapy123's Avatar
Default 2005 T&C turn signal/brake light out?
Not the bulb, I replaced the bulb, inspected all contacts, the wires look fine, everything looks clean.
The taillight works, but the breaklight/turn signal does not. The turn signal blinks really fast. Front works (but blinks really fast).
Auto parts store said there is no flasher on this vehicle...i'm guessing this function is now controlled by a computer? BCM?
what else could be causing my problem?
Old 01-24-2011, 08:32 PM
Djinn-n-Tonic's Avatar
Where are you located???? Is this a US model or european Export.??? ....Left or right side???
Old 01-24-2011, 09:33 PM
oapy123's Avatar
US model, right side
Old 01-24-2011, 10:58 PM
RIGHT REAR LAMP ASSEMBLY - BLACK 6 WAY
CAV /CIRCUIT/ FUNCTION
1 L62 18WT/BR (EXCEPT EXPORT) RIGHT REAR TURN SIGNAL DRIVER
1 Z362 18BK/BR (EXPORT) GROUND
2 L62 18WT/BR (EXPORT) RIGHT REAR TURN SIGNAL DRIVER
3 L50 18WT/TN (DIESEL) PRIMARY BRAKE SWITCH SIGNAL
3 L78 18WT/OR (EXCEPT EXPORT/EXCEPT TRAILER TOW) FUSED PARK LAMP RELAY OUTPUT (RIGHT)
3 L50 18WT/TN (GAS EXPORT) BRAKE LAMP SWITCH OUTPUT
3 L78 18WT/TN (TRAILER TOW) FUSED PARK LAMP RELAY OUTPUT (RIGHT)
4 L1 18WT/LG (EXCEPT TRAILER TOW) BACK-UP LAMP FEED
4 L1 18 WT/PK (TRAILER TOW) BACK-UP LAMP FEED
5 Z362 18BK/BR (EXCEPT EXPORT/EXCEPT TRAILER TOW) GROUND
5 L38 20WT/YL (EXPORT) REAR FOG LAMP SWITCH OUTPUT
5 Z362 18BR/OR (TRAILER TOW) GROUND
6 L78 18WT/OR (EXPORT) FUSED PARK LAMP RELAY OUTPUT (RIGHT)
2005 T&C turn signal/brake light out?-814f85cc.jpg
A basic 12 volt test lamp ....Check powers at pins..1,2,3, and grounds at 5
If all ckts are good...replace r/r lamp assembly
Old 09-30-2021, 01:27 PM
swallace's Avatar
Hi, Were you able to solve this issue? My father is having same problem 2005 Chrysler Town & Country no brake lights, no turn signals.
swittie
11-10-2020 02:02 PM
footballguyxx
04-22-2012 05:23 PM
quintr
04-30-2011 07:32 PM
Bible Believer
05-08-2008 12:11 AM
GSKI
13
09-11-2007 09:33 AM
Quick Reply: 2005 T&C turn signal/brake light out?
