2008 T&C stalling, rough idle, hesitation
Like already stated: I would do the "key Dance" first
1. Have a pencil and paper handy.
2. Get in the car, close the door.
Perform steps 3-7 fairly quickly (less than 3 sec's total time).
3. Turn key to 'ON' position
4. then back to 'OFF'
5. then to 'ON'
6. then back to 'OFF'
7. then to 'ON'
If there are any stored codes, they will appear immediately, in place of the odometer.
Once the codes have been displayed, you'll see "-----". If there are no trouble codes, the dashes will be the first item displayed.
After a few seconds, the display changes to "-dOnE-".
5. then to 'ON'
7. then to 'ON'
5. then to 'ON'
7. then to 'ON'
5. then to 'ON'
7. then to 'ON'
So steps 3 thru 7 could read:
4. then back to 'ACC'
5. then to 'ON'
6. then back to 'ACC'
7. then to 'ON'
#18
I do this all the time.
Mr. Fixit
#19
Well, I can bank the info on clearing codes for next time 'cause I got no codes thrown when I used the technique. So, we have a suggestion of possible temp sensor, a buddy who mentioned it may be a spark plug or plug coil starting to go. Any other ideas and more importantly, what should I do next? How do you test a temp sensor? Would it have thrown a code if it were a sensor? Same question about the possible plug or coil issue. Thanks for any advice on how to procede from here. Still bucking when holding at constant, steady speed and had a stall 3 days ago (outside temp was about 45 degrees but not sure if temp related issue yet as we haven't warmed up enough in Boston to differentiate).
#20
I think you should do a full service first;
Air filter, fuel filter, oil & filter, spark plugs. If this has helped but still not 100% then replace the coil packs. At least you now know you have a good base to start from with further fault finding and knowledge that your engine should be in a better state of health.
