Auto GBox gone crazy as has the electrics inside
Old 10-16-2014, 02:04 PM
nobertusmaximus's Avatar
Unhappy Auto GBox gone crazy as has the electrics inside
Please HELP, My G Voager Has gone nuts.
Symptoms
Gearbox sometimes works ok sometimes wont go past 2nd gear.
Tail/HeadLights stay on after ignition off
Dash lights stay on after ignition off
Radio/Nav Unit stays on after ignition off
Windscreen Wipers dont work
Fuel Gauge is Dead and the OHD shows there is 0 range (theres fuelin the car)
SnapOn Scanner said it was the speed input sensor. but why would all the other electrics gone mad.
Elec. Doors and Tail Gate only works once you first plug the battery in then they stop working.
RH Side Mirror Folds out too far.
Checked
The Battery fully recharged, tried 3 types, incl GEL Optima Red Top same issues.
Alternator charging perfectly.
Engine and Turbo are spot on, pulls like a train.
Gearbox gear changes are smooth no sharp jerks.
Other Electrics All works
HEEEEELLLLLLPPPPP PPPPPLLLLLLLEEEEEAAAAAAASSSSSSEEEEE!
Old 10-16-2014, 03:59 PM
Yes, It's going nuts...But Engine and Gearbox working as they should...Interesting...
What's codes and your car info..Its obviously rebooted..Maybe looksee at contacts underside of fuse box..Big rightup on her about this box and its contacts..
Think you'll hear more about this...
Old 10-16-2014, 04:32 PM
Thanks for your reply, I shall check the connectionsand earthing as that seems to be mentioned a lot.
The gearbox is gone bad too, most of the time wont switch upwards of 2 but then it works fine sometimes. Im stumped, really really hope its dodgy connections.
Old 10-16-2014, 05:50 PM
What you can do and what you must pay others to do for you. You can do the basics of 'wiggle tests', green verde contacts, and high ohms of resistance.
IPM [TIPM] or earths' [ground circuits] are both good bets for a solution. It would be nice if we knew what year it was. A ground circuit is a very bad tempered mistress it will always fight to make its way back home - to the negative battery terminal, if its path is blocked that component with create havoc, even the negative battery cable itself can be a good supect fro replacement. Likewise 3 computers run the car, each is routed through the IPM, the contacts if corroded in the multi layer IPM [signal - voltage - grounds] will also create the kind of multiple havoc you have described in #1.
Old 10-17-2014, 03:28 AM
Leedsman's Avatar
My money is on the battery grounding circuit -- all of it. Be sure the battery post connectors are bright-metal clean too.
Leedsman.
Old 10-17-2014, 04:29 AM
Default model and year Chrysler Grand Voyager 2.8 diesel on 2004
Symptoms
Checked
Sorry meant to detail the year, model....
Its a Chrysler Grand Voyager 2.8 diesel on 2004 p
Old 10-17-2014, 07:06 AM
Old 10-17-2014, 10:49 AM
Just wanted to add, I did the keydance and I get P1652.
Is that a short somewhere?
Old 10-17-2014, 11:36 AM
tfb's Avatar
tfb
tfb is offline
1652 is a communications bus error.
Somewhere there is a fault on the bus wiring or there is a module that is affecting the bus. Bus wiring drawings can be found here
https://drive.google.com/file/d/0Bw6...ew?usp=sharing
Regards
Richard
Old 10-20-2014, 02:19 PM
nobertusmaximus...Any result from Roman Forum about this my good Centurion.
God I just had to ask this.
Daniel Williamson
05-05-2015 11:49 AM
terryd999
11-03-2013 01:56 PM
jimhild
11-17-2010 09:00 AM
MikeF
06-10-2010 09:20 AM
gaz440
01-06-2010 01:10 PM
Quick Reply: Auto GBox gone crazy as has the electrics inside
