Body Control Module - Chrysler Forum - Chrysler Enthusiast Forums
Thread Tools Search this Thread
Old 05-29-2013, 09:37 PM
Default Body Control Module
The body control module went out again this week after it's second replacement. What could be causing this? I just want it fixed...it is scary driving a car with this issue.
Old 05-30-2013, 02:44 AM
Model year and symptoms would help.
Old 05-30-2013, 05:55 AM
Default bcm
Sorry...2004 Chrysler T&C. Symptoms: Headlights, Tail Lights, Wipers, Windows, A/C, Radio, Horn All Stop Working With No Warning.
Old 05-30-2013, 08:58 AM
andyb2000's Avatar
Might be a long shot, but does the coolant water bottle overflow/exhaust/outlet (whatever it is) pipe point straight onto a rather large loom of wires that have 'joining' tape around them?
This is what I found on mine, and discovered water droplets always sat on this cable/joint. I redirected the overflow pipe elsewhere and my BCM doesn't seem to go nuts as often as it used to.
Coincidence possibly, worth a go? probably!
Old 05-30-2013, 04:41 PM
How long did the first replacement BCM last? Was any maintenence performed just prior to the start of this?
The BCM gets power directly off the battery bus from 4 sources. Did any of the 4 fuses blow?
BCM fuses:
40 amp fuse #20
20 amp fuse #24
40 amp fuse #19
15 amp fuse #14 (IOD)
Did any other systems die such as power doors, door locks, brake lights, interior lighting, turn signals, power outlets, etc?
When you say the A/C died does that mean blowing hot air or no air at all? Any other heater A/C panel functions stop working?
What I'm getting at is it appears (looking at wiring diagrams) the Front Control Module (FCM) may be just as likely a culprit. More info will help determine that.
Old 10-24-2013, 07:53 PM
Where does one get the schematics for Chryslers, specifically a '94 Ney Yorker?
Thanks,
Thread Thread Starter Forum Replies Last Post
body control module amadsen Chrysler Pacifica 2 03-24-2012 07:17 PM
1991 Fifth Ave Body Control Module PapaGeorgio 300M, Concorde, LHS, New Yorker 0 08-20-2009 02:44 PM
1994 New Yorker - Wipers Misbehaving, Body Control Module Issue (Electrical Diagrams) JakFrost General Tech 3 05-28-2009 06:52 PM
Dash - Tach - Body Control Module issue? Bubble_City Chrysler 200 & Sebring 7 05-04-2009 06:23 PM
BODY CONTROL MODULE CSPEISER 300M, Concorde, LHS, New Yorker 1 07-24-2007 11:25 PM
Tags
2004, 28, ac, bcm, blows, body, chrysler, control, forum, hot, light, modu, module, stop, tc, voyager
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
