Chrysler Voyager 1999 Brake lamp blinking help!
Old 12-21-2013, 02:52 AM
Bazer79's Avatar
Default Chrysler Voyager 1999 Brake lamp blinking help!
Hello,
Have Chrysler Voyager 1999 and the brake lamp on dashbord is blinking constantly.
There is brake oil to max level and the brakes seems to work fine..
anyone knows what it is?
Chrysler Voyager 1999 3.3L V6
Thanks..
Old 12-21-2013, 03:30 AM
tfb's Avatar
tfb
tfb is offline
check the handbrake is fully off and that the switch on the handbrake is not stuck.
Regards
Richard
Old 12-21-2013, 03:33 AM
Leedsman's Avatar
A regular blink would suggest something has been detected by the micro to bring your attention. Some brake pads have an electrical contact to signal end of life, it may be ABS related etc.
The handbook, or someone knowlegeable here should show. Needs your immediate attention of course being brake-related.
Leedsman.
Old 12-21-2013, 04:42 AM
Bazer79's Avatar
have checked already that switch to handbrake is fully off and the switch is not stuck..and the handbook dont say anyting more than needs to check brake oil level and its on max..
Old 12-21-2013, 06:57 AM
Leedsman's Avatar
Have a look-see if there is a wire going to the brake pad area. Then see if the pads are abnormally worn down. I had an older Mercedes 300D using that idea, and there are connexions between Chrysler and Mercedes...
Leedsman.
Old 12-21-2013, 11:11 AM
chrysler1's Avatar
Leedsman.
That was my first thought. Had the same problem on my daughter's Peugeot some months ago.
Old 12-21-2013, 01:01 PM
estrika's Avatar
remove all electric plugs that goes to brake pads, light should change to always on, if this happens them you have one or more brake pads in end life, you just need to find out what ones.
Old 12-22-2013, 08:06 AM
chrysler1's Avatar
My daughters brake light came on, only when braking,as the contacts came into contact with the steel disc.
Old 01-02-2014, 02:31 AM
Bazer79's Avatar
There is no electric wire to pads on this car and all brake pads are almost new..
Old 01-02-2014, 02:34 AM
Bazer79's Avatar
There is no electric wire to pads on this car and all brake pads are almost new.. and the brake lamp start to blink even not engine is on..
Quick Reply: Chrysler Voyager 1999 Brake lamp blinking help!
