How to change brushes on alternator voayager 1994
Hi
i have some charge problems with my car, it suddenly just stop charging, i pretty sure its the brushes thats need to be changed, but what is the easiest way to change the brushes , is so darn tight back there
and is there somewhere on the wide web where i can find a scematic of the engine
Chrysler voyager 1994 3.3 AUT
It will impossible to change the brushes without removing the alternator - and finding replacement brushes is difficult - though model shops have proved useful in the past.
In my experience it is easier just to change the alternator.
Try Ebay for a new or second hand one with a guarantee.
I have a wiring diagram but am unable to attach it to this reply.
take out the alternator
Hi
tnx for the info
but is it someone who know in witch step i have to go to take it out
our is it just take out the 3 screws
how is the altornator tighten?
can i do this easly on the street , hard to move to car from where it stands
/tord
tnx for the info
/tord
You need to disconnect the battery then disconnect the push in field wire and remove nut holding other wire (both on back of alternator).
You then need to remove the serpentine belt which has an automastic tensioner pulley just below the alternator (use a long spanner and turn the tensioner clockwise and remove belt - two people are better than one).
Then remove the nut holding top of alternator, then remove bolt from bottom.
Replace and then all in reverse.
Oh you mau have to remove the windshield wipers, arms and shield as well.
Hope this helps
Hope this helps
flaxman
09-05-2011 02:10 AM
1994, 1994crysler, 94, alternator, alternators, brushes, change, chrysler, install, nut, remove, removing, repair, replacement, voyager
