Flex Plate Issues
Flex Plate Issues
I have a 2000 Chrysler Town and Country 257,xxx 3.3L Flex. I have the code P1391. It started on a trip from MO to IN. It would buck at about 3000-3500 rpm but at 75 down the highway it drove great. I made the trip up and back and now that I am home the buck and knock is getting worse and worse. It knocks and bucks randomly now at any RPM under load. I have replaced the crank sensor, cam sensor, egr valve, spark plugs, wires, all to no avail. I have not been able to get under the van yet to check the plate through the inspection plate. I would like to know if anyone has any pointers or advice before I start this adventure. I would also like to know where to find a new flex plate. I cannot for the life of me find a new one anywhere online. I found these two plates:
through another forum that claim they would work but no one ever confirmed this. Amazon shows it will work but any other site shows that it is incompatible. Oreilly and Autozone both told me it was a dealer only part and I can only imagine how much their asking price could be. Any help would be a blessing. Thank You
I do not want a used one. I have seen that this is a common problem and I want to avoid a used but however I do not want to spend as much as the dealer is asking. I cannot find any on advanced auto parts. If you could send me a link that would be great.
You are a life saver. Thank You my friend. I do not know why I could not find that on the website. I tried searching under my vehicle and just a general search and all that I could find were the nuts and bolts but not the actual plate. You have been a great help. If there is any other advice you may have I would be all ears. I am very certain it is the flexplate and I do plan on getting under it this week to try and see it through the inspection plate. Again thank you greatly!
I have contacted APT and I was told that the one from advanced does not fit my van. This is what they said:
Josh,
Advance does buy from us, but their application data is wrong in this
instance. I will work with them on the correction.
Regards,
Ron Haimbaugh
Data Content Manager
ATP-Inc
Direct Line: 847-597-9168
Fax 847-637-8357
cid:image001.png@01CA888F.B6FAC8B0
Sent: Monday, October 29, 2012 9:19 AM
To: 'Ron Haimbaugh'
Subject: RE: flex plate
No, we do not have a flexplate available for this vehicle at this time.
From: Ron Haimbaugh [mailto:rhaimbaugh@atp-inc.com]
Sent: Monday, October 29, 2012 9:00 AM
To: 'Bob Benisek'
Subject: FW: flex plate
Hi Bob,
Will our Z-331 match the OEM flexplate on a 00 3.3L Chry minivan?
Thanks,
Ron Haimbaugh
ATP-Inc
Fax 847-637-8357
Sent: Monday, October 29, 2012 8:26 AM
To: Ron Haimbaugh
Advanced Auto Parts carries another flex plate:
ATP Automatic Transmission Flexplate
Part No. 04651
Advance Auto Parts
-transmission-flexplate-atp_15610014-p?searchTerm=flywheel
<Advance Auto Parts
c-transmission-flexplate-atp_15610014-p?searchTerm=flywheel&SID=1c9yg8rtg26i
1&cm_mmc=aff-_-cj-_-4178555-_-10711125#fragment-2>
&SID=1c9yg8rtg26i1&cm_mmc=aff-_-cj-_-4178555-_-10711125#fragment-2
Would this one be correct or does ATP not make one for my van at all?
-Josh
To: "'Joshua B'" <joshua_kittery@yahoo.com>
Cc: "'Bob Benisek'" <bbenisek@atp-inc.com>, "'Anna Richardson'"
<arichardson@atp-inc.com>
Date: Monday, October 29, 2012, 7:42 AM
Hi Josh,
We do not have a flex plate part number for this application. Z-331 fits on
older mini-vans, but not a 2000. This is a snap shot of the applications
for Z-331 from our electronic catalog. ATP - automatic transmission replacement parts
Ron Haimbaugh
ATP-Inc
Fax 847-637-8357
From: Anna Richardson [mailto:arichardson@atp-inc.com]
Sent: Monday, October 29, 2012 7:31 AM
To: 'Joshua B'; order@atp-inc.com
Cc: 'Bob Benisek'; 'Ron Haimbaugh'
Joshua,
I have forwarded your question to our Tech Support Dept. Someone should
respond shortly.
Please contact me if you have any questions or concerns.
Thanks,
Anna Richardson
ATP, Inc
Customer Service Specialist
Phone: (847)967-6790
Fax: (847)967-8686
Sent: Sunday, October 28, 2012 3:28 PM
To: order@atp-inc.com
Subject: flex plate
I need to know if this part number is the correct flex plate for a 2000
Chrysler Town & Country 3.3L Flex Fuel 2wd. Thank You.
ATP Z-331
-Josh
Can anyone else please help? Thank You.
Josh,
Regards,
Ron Haimbaugh
ATP-Inc
Fax 847-637-8357
To: 'Ron Haimbaugh'
To: 'Bob Benisek'
Hi Bob,
Thanks,
Ron Haimbaugh
ATP-Inc
Fax 847-637-8357
To: Ron Haimbaugh
Part No. 04651
Advance Auto Parts
<Advance Auto Parts
-Josh
Hi Josh,
Ron Haimbaugh
ATP-Inc
Fax 847-637-8357
Joshua,
respond shortly.
Thanks,
Anna Richardson
ATP, Inc
Fax: (847)967-8686
Subject: flex plate
ATP Z-331
-Josh
OldWreck
09-28-2014 04:47 AM
04-28-2006 05:53 PM
Racinfan83
12-10-2005 11:50 PM
