Freon charging for 2010 Chrysler T&C Limited
had a leak in the rear condenser of my 2010 T&C. I replaced the condenser and O-rings and evacuated out the system and it holds a good vacuum now. What I want to know is, I am going to replace the accumulator and wanted to know how much oil I should add to the new condenser? I also wanted to know what the pressure readings should be for the hi and low gauges when charging the A/C system? I understand the sticker states about 40.8 ounces of Freon (yeah I know its not actually Freon) is needed with rear a/c. However when it was low and I added Freon it seemed to need more than that to be cool. A Chrysler service guy said that the sticker was more of a guideline and said the the pressure on the low side would be about 35-40 and the high side I should have at about 250 but that seemed high to me. Any help would be appreciated,
put like an 1 oz of oil The pressure is all relative to the temp outside
R-134a System Pressure Chart | AC Pro
thanks for the reply. Do you know what the temp should be reading out of the vents or at least a range?
eldnpat@gmail.com
08-23-2015 07:14 PM
Diamondssleeper
08-14-2011 01:01 AM
