Sponsored by:
Sponsored by:
Grand Voyager 2004 Alarm Issues
Old 07-19-2012, 01:38 AM
travelmad's Avatar
Default Grand Voyager 2004 Alarm Issues
Hi,
Having an issue with my alarm, but only at night!
Will go off at random times, each night, never in the day.
The only way around it is to press the lock button 4 times.
What can i check?
Thanks!
Old 07-19-2012, 09:28 AM
Originally Posted by travelmad
Hi,
What can i check?
Thanks!
Introduce the fob to the car again, get them antiquated, try a reconciliation!
- turn the key to the start POS but do not START the engine
- when the checks stop lock and unlock the doors FROM the FOB several times
- - - this will re-marry the KEYFOB and the PUTER
- lock in the usual way with the KEYFOB, does the alarm function normally ? - if not do the following :
__________________________________________________
- disconnect the batter for 5 minutes, your FOB and car are now divorced .. .. then reconnect the battery
- your battery and FOB are now acrimoniously divorced and won't speak to each other
- - - the PUTER will read all BUS's and door locks, do all checks, you will hear lots of clicks
- start the car, while it warms up re-set the missing settings from the radio and the roof display
- stop the engine and lock in the usual way with the KEYFOB - does it work now ?
NOTE : an afterthought - when you think you have locked and alarmed etc the vehicle you / it hasn't finished. The vehicle polls the computer BUS for 15 minutes checking windows / doors / radio and lights left on etc. Only then is the alarm function fully functioning.
Old 07-25-2012, 01:22 AM
travelmad's Avatar
Thanks for that. So far so good.
Old 07-25-2012, 07:33 AM
- good , pleased to help !
Old 10-29-2013, 07:52 AM
Coquenão's Avatar
I'm sorry for the diggin', but this seems to be similar to my problem..
In this case, it's a '08 Grand Voyager 2.8CRD Stow'N'Go. Almost every day the alarm triggers at night.. It is properly locked. Should I try what's stated on this topic?
Thank you in advance!
Vonhofinvule
01-05-2015 07:55 AM
wadrok01
07-01-2013 06:43 AM
Ian
08-09-2009 05:28 AM
Boric99
08-24-2008 09:46 PM
Quick Reply: Grand Voyager 2004 Alarm Issues
