Sponsored by:
Sponsored by:
Grand Voyager.. How do you remove right hand sliding door inner trim panel
Old 04-26-2011, 10:57 PM
crispy's Avatar
Question Grand Voyager.. How do you remove right hand sliding door inner trim panel
Grand Voyager (Town & Country) 2.8CRD Sept 2006 Reg (UK). Anyone have a detailed description on how to remove right hand sliding door inner trim panel. I am nervous about just pulling at the trim . The fasteners seem to be slotted into the door frame. This would suggest you need to slide panel up to release. Any ideas please.
Old 04-28-2011, 10:11 AM
SpudlerT+CTouring's Avatar
2006 Reg UK? Do you happen to mean a 2006 RG and does UK mean United Kingdom?
I do have the service manuals for the RS models and the RG (Export) Models I can look and see what I find although I can tell you that I removed my Right Side rear trim to access the rear HVAC and fan area and you need to be fairly careful and use a trim removal tool or likeI did and Modified a Vaughn Superbar. It reminds me of a section of flatbar Id say 2"W X .125" Thick radiused a bit on one end with a couple holes for pulling nails and the other end is bent 90 degrees to allow for major prying of plywood or larger nailed together pieces, I started wit a large scredriver but quickly realized I could easily damage the plastic trim easily.
I have to remove my left side to replace the plastic locking devices as I found they are no longer holding it on plus I noticed my right door power slider seems slower then the right so I want to lube the cable and any other parts that need it so I need to find out how to remove the panels anyway.
Mine is a RS so I am not sure if mine would be different then yours if it is I have info for both models.
Old 04-28-2011, 10:23 AM
I hope this helps I will look for more info also
Old 04-29-2011, 09:36 PM
crispy's Avatar
Thanks Spudler. Will try tomorrow and let you know how I get on. If successful and I learn something I'll post some details.
I live in United Kingdom (UK) and 2006 Reg means that the vehicle was first registered in the UK year 2006.
asifakhtar
08-20-2013 10:22 PM
avissvcmgr
01-21-2010 07:08 AM
Raybart
12-20-2008 10:47 AM
Newtoo300s
06-02-2008 01:56 PM
Quick Reply: Grand Voyager.. How do you remove right hand sliding door inner trim panel
