Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Voyager & Town & Country
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 11-20-2011, 02:10 PM
Angry Headlight issues
Where to begin.... A few days ago i notice that i had a headlight out, on the passenger side, so got a new bulb and replaced it, only to fine still no joy, now I have side lights that wont switch off, high beam works, but no head lights, the horn has stopped working and the int lights work but not when opening the doors. the dash lights work when the switch is turned on, and they turn off when its turned off. Im not sure where to start looking for the prob.....Could it be a bad earthing somewhere???Hope someone on here has some idea....Its a 1998, 3.3 le if thats any help.......
Many thanks in advance
Austin
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 11-20-2011, 10:22 PM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
checked fuses?
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 11-21-2011, 12:55 AM
All Body Control Module (BCM) related. Try resetting it by pulling the IOD fuse for 2-3 minutes. High beam headlights bypass the BCM.
Old 11-21-2011, 09:07 AM
not a bcm issue this is an older system there are 2 relays 2 fuses 2 separate wire sections if both were an issue I would say yes but only one bulb does not work check the fuses for the headlights first.
__________________
KKeller608@aol.com
Old 11-21-2011, 02:37 PM
I'm taking "...now I have...no head lights" to mean both low beams are out. Is that correct AJcars? Yup, 4 fuses, high and low beam for each head light. Agreed, passenger side low beam is likely a fuse for reasons Chrysler Tech stated if only only passenger side is out. Otherwise, BCM has a controlling function for both low beam head lights, horn, parking lights, dash and interior lights. You can try a BCM reset on those systems.
Old 11-24-2011, 03:51 PM
Thanks for your replies.....After testing everything I have come to the conclusion that there is a fault with the BCM, because if i bypass it all works fine. Will try and pick one up tomorrow and Will post the results when done....
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
