Sponsored by:
Sponsored by:
Help with P0442; P0455; P0456...
Old 11-21-2008, 10:24 PM
jquinones's Avatar
Default RE: Help with P0442; P0455; P0456...
we are here to help each other!! you are a big help forsimple thing or complicate thing!!
thanks a lot, share experiences to help others!!
Old 11-21-2008, 10:27 PM
jquinones's Avatar
it is T&C, where can I find this vent valve? maybe any sensor? like the one I see when I change the rubber lines with wire conected to it and the lines go by there.
thanks
share experiences I like to say here, help others to same money and learn, learn learn, input
thanks guys
Old 05-16-2010, 11:17 AM
hugo1964's Avatar
Originally Posted by JeepAndAVan
Remove the air cleaner box under the hood (big black box on the passender side under the hood). look for two plastic tubes runningunder it from front to back. one of them makes a 90 degree transistion to a tube coming up from below back by the firewall. Check the piece of rubber hose that connects these two tubes. mine was dryrotted and cracked so I replaced it and all was well (5/16" vacuum hose available at an auto parts store. Get enough to make a loop when you replace it instead of just a 90 degree bend. This will keep it from cracking in the future). The other places to check would be the gasket on the gas cap and the filler neck assembly as it can rust out and set these codes. you may have to trace and check all the vaccum lines that are a part of the fuel evaporative system...
The 1 1/2 inch rubber hose connector was cracked as you mentioned. A quick replacement fixed the problem. Would've never found that out wthout your help.
Many thanks,
HUGO
DKats
07-09-2017 07:33 PM
rocksockdoc
10-17-2013 11:12 AM
Sarape
10-26-2011 01:13 PM
jquinones
11-10-2008 07:09 PM
selewoh
11-04-2007 09:02 PM
Quick Reply: Help with P0442; P0455; P0456...
