Hoat coolant
Old 09-13-2014, 07:09 PM
Hodges710's Avatar
Default Hoat coolant
I bought 3 bottles of hoat coolant (zerex 05) to do my flush and refill and noticed the color of this new stuff is yellow. I know there is no worries when doing a full flush but curious if the red stuff is still out there?
Old 09-14-2014, 01:05 AM
Dealer
Old 09-14-2014, 04:33 AM
Leedsman's Avatar
Please note these vehicles have aluminium radiators and won't flush as the old copper and brass ones would. Be careful therefore what you put in there in terms of flushing mixture -- that it won't attack the aluminium.
HOAT antifreeze is fine whatever color it is, so long as it declares on the bottle/container that it IS in fact HOAT. It usually says 5-year life too. Comma's HOAT antifreeze is called "go-5".
You are doing well if you're changing the antifreeze before the 5-year limit. You are saving yourself a lot of money by not having to replace the radiator and the thermostat, as I know to my cost. That was one of the neglected jobs before I bought my GV.
Leedsman.
Old 09-14-2014, 07:08 AM
Hodges710's Avatar
Old 09-14-2014, 07:13 AM
Hodges710's Avatar
Leedsman.
Thanks, in this case what I meant by flush was just draining the old and using distilled water to get all the old out before refilling, not adding any kind of cleaner/flush stuff at all. The old coolant looks clean but failed the floating ball test, only had one of the 5 float.
Old 09-14-2014, 07:39 AM
Flush - but never back-flush, and only ever flush with tapoline. Many [including parts distributors] fitters laugh when distilled is asked for. Distilled is a quid a gallon the Hoat / distilled ratio is 50/50%, so one gallon of hoat and one gallon of distilled. I used comma & distilled but the Zerex is the same spec. Colour varies country to country, I'm not sure there is an actual internationally agreed standard.
I just partially pulled the bottom hose, put the garden hose in the expansion bottle, filling was correlated to the rate of empty-ing, set the heater to full belt [flushes the matrix] and started the engine [caveat emtor applies]. When the colour and the crap was out I replaced the bottom hose and filled at 50 / 50, then left it running for 20 minutes to burp. Always check level the next day - just in case.
TomC
10-23-2014 07:16 AM
Merlecollins
01-31-2014 06:07 AM
neh218
64
11-28-2011 03:54 PM
adhvanika
06-11-2008 01:17 PM
JXI101
07-13-2005 09:56 AM
Quick Reply: Hoat coolant
