how much pressure/many cans of R134a - Chrysler Forum - Chrysler Enthusiast Forums
Thread Tools Search this Thread
Old 08-20-2009, 12:01 AM
Default how much pressure/many cans of R134a
i have a 2000 chrysler grand voyager, the a/c wasn't blowing cold and the low-pressure line was reading 75 psi with the engine on and a/c set to max+recirc, 70 psi with the engine turned off- took it to an a/c place and the technician said that the compressor had too much shaft play. so we replaced the compressor, filter/drier and expansion valve. tried to charge the system but after a can and a half of freon, the pressure gauge was bouncing around, sometimes reading a max of 15 psi. how much pressure/many cans of R134a do i need to pump into the system before the pressure stabilizes and the air starts blowing cold?
Old 08-20-2009, 07:12 AM
look on the blue label under the hood see which system u have single or duel air it will tell u how many LBS u will need 1 small can 12oz is 1 lb
Old 08-20-2009, 12:16 PM
i'll do that. i know it'll be 32-48oz, but my main concern is when i was charging it, the gauge was jumping around, usually after disconnecting the gauge/nozzle from the a/c line then reconnecting it, would read 15 psi then go back down when starting to charge again. so i'm wondering if this is normal or if i should see a steady increase in the pressure.. and if so does it start right away or after a certain ammount of freon has been put it
Old 08-20-2009, 10:49 PM
U cant go by the gauge when adding it because u are adding plus what U are reading off of the already pressure in the system.
Old 08-21-2009, 12:46 AM
thank you, i think i understand where you're going. in a nutt shell i can't expect to see a rapid increase in pressure while charging and will only see the true pressure after releasing the trigger, disconnecting the charging line then reconnecting it? 15 psi was the last measurement i had before i stopped charging for fear that i didn't connect something tight enough(going to recheck the expansion valve retrainer plate) but how much do i actually want? do i go off of the 25-45 psi that's on the gauge? or should i consult the chilton's manual? or an auto part's store? thank you again for your help
Thread Thread Starter Forum Replies Last Post
1999 Sebring Convertible JXI V6 - Many, many issues... DJBowens Chrysler 200 & Sebring 3 04-26-2011 06:44 PM
Are You Receiving TOO MANY CF Emails? Dodgegirl19 New Member Area 1 04-10-2011 07:08 AM
2001 chrysler catch cans rambo28173 300M, Concorde, LHS, New Yorker 0 05-25-2009 08:35 PM
How many dogs does it take to change a light bulb? Midnight 85 Off Topic 0 03-23-2006 07:49 AM
Are You Receiving TOO MANY CF Emails? Dodgegirl19 Forum Issues 0 11-18-2005 03:24 PM
Tags
15psi, 2000, 55, ac, acan, add, cans, charge, chrysler, cruiser, grand, muchr134a, pressure, pt, r134a, voyager
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
