Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Voyager & Town & Country
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 11-05-2011, 03:42 PM
Default Intermittent P0300 & P0172 Codes
Hi all, I have an '02 T&C with 178K. The last 2000 miles I've been experiencing intermittent issues with a P0172 and P0300 code coming in. I've also seen pending codes for misfire on every cylinder @ one time or another except for #4. New plugs and wires, couple bottles fuel injector cleaner. Sprayed down butterfly & throat with carb cleaner. Each one helped for a little bit, but it eventually comes back.
I pulled the freeze data today:
Code: P0300
RPM: 672
Coolant Temp: 93 F (though the gauge was @ half)
Load:21.1%
MAP Sensor:57 KPA
Short Term Fuel Trim 1: -18.8%
Long term Fuel Trim 1: -10.4%
Short Term Fuel Trim 3: 20.3%
Long term Fuel Trim 3: -82.5%
Speed: 32 MPH
As with everyone else, money is tight and if I can get a few ideas it would be a great help .. Thanks
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 11-05-2011, 10:26 PM
Old 11-05-2011, 11:01 PM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
well either the computer us using is not accurate or u have some typos or there is a computer issue
@ 32 MPH u @ 672 RPM not likely
and fuel trim can not exceed 35% + or -
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 11-06-2011, 05:48 PM
Thanks for the feed back .. I read the freeze data with a Actron CP9175, I re-checked the information and there were no typos .. When you said the computer issue, are you talking about the van's computer or the reader?
Its funny, some days it will purr like a kitten and the light will be off and the next its running rough. The P0300 code comes in everytime, usually with 2 specific cylinders misfiring code pending. The P0172 about half the time. I'm clearing the codes once a week or so, if its been on for a few days. I cleared the codes and will check the freeze data again when the light comes on.
Old 11-06-2011, 09:05 PM
the scanner then must be faulty use a different one
__________________
KKeller608@aol.com
Old 11-17-2011, 04:40 PM
Read the freeze data again. No one has a reader that shows the freeze data, so I had to use my existing one.
The P0172 code triggered it this time.
RPM 1856
Load Valve % 29.8
Map Sensor 92 KPA
Coolant temp 203F
Short Fuel Trim 1 -2.2%
Long Fuel Trim 1 -25.6%
Short Fuel Trim 3 -51.0
Long Fuel Trim 3 97.6
Speed 59 MPH
I know you said the fuel trim is out of range. Is there a sensor that could be bad to give these readings ??
I am also getting P0301 and 0305 constantly now. Is there a way to test the coil pack ?? I was getting misc misfires through the past week or so and now these two are coming in regularily.
Old 11-19-2011, 03:34 PM
I pulled the fuel injector wiring harness plug and found the insulation to be melted. Taped the wires and protected with fiberglass tape. Drove it about 30 miles and it had a little miss in it @ idle, but wasn't misfiring and running smooth @ 55 mph. The SES light came back on with the P0172 code again. The freeze data is similar to before. Does the van need to be run for a while to get everything to reset right ??
Old 11-19-2011, 07:14 PM
if u can still feel the issue then it is still there
__________________
KKeller608@aol.com
Tags
0172, 06, 2006, 37, actron, chrysler, country, fuel, intermittent, jeep, p0172, p0300, po172, po300, town, trim3
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
