Sponsored by:
Sponsored by:
Minor coolant loss/intermittent coolant smell inside car
Old 11-19-2015, 05:38 PM
JaxJim's Avatar
Default Minor coolant loss/intermittent coolant smell inside car
2002 t&c 3.8. New radiator and cap and t-stat. Doesn't overheat and I don't see any leaks but now and then I get a coolant smell inside car (up to temp and heat and a/c off) and windows fog up slightly. Coolant loss is about 2 cups over a 2 week period. Oil shows no sign of water. No sign of leakage on water pump. Does this sound familiar to anyone? Thanks for any help!!
Old 11-19-2015, 09:59 PM
heater core leaking
Old 11-21-2015, 05:19 AM
I don't know if it works on heater cores but I have had 100% success in using Radweld or similar on engine, radiator and pipework leaks. Might be a quick cure or temporary sollution at this time of year.
Old 11-21-2015, 11:29 AM
JaxJim's Avatar
I will definitely look into that. If it is the heater core, from what I hear and see, it is a bear to get out!
Old 11-21-2015, 11:32 AM
JaxJim's Avatar
heater core leaking
I don't suppose there is a way to test that first?
Old 11-22-2015, 10:18 AM
pressure test it look for leaks
Old 11-22-2015, 12:16 PM
Best to pressure test it when coolant is cold because when coolant heats up the metal expands and stops the leak..was a problem with big hulking mainline diesel engine cooler groups back then when the coolant ran out when engine shut down for even a day.
Racer
12-01-2013 01:08 PM
Evertb
01-17-2013 01:12 PM
SSJ
04-12-2011 04:36 AM
musicfreak2195
03-29-2009 08:55 AM
01-01-2005 05:41 PM
Quick Reply: Minor coolant loss/intermittent coolant smell inside car
