MY05 console led replacment.
Old 08-19-2016, 12:05 PM
minibull's Avatar
Default MY05 console led replacment.
Hi guys, I have search in the forum but I have not found about this console led replcement for a 2005 MY.
Does someone knows the correct led type for the replacement?
Is the led for the buttons light in the upper console.
Thank you in advance.
Old 08-22-2016, 07:48 AM
andyb2000's Avatar
Hi there,
Believe it or not, that IS NOT an LED, it's a regular tungsten bulb with a blue rubber cover over it! I've replaced quite a few of these now and i do replace them with LED.
The main problem/difference is that an LED doesn't diffuse light in the same way, it's a lot more targeted, so you either need an LED with very wide beam or replace with a regular panel bulb.
Search ebay for rectangular LED and you should fine what I've used in the past:
Hopefully that'll help.
Oh and a word of caution, the boards and circuit traces are VERY fragile, I've had to re-make a lot of them with replacement wires because as soon as the soldering iron touches them to remove the old bulb the traces peel off the board and fail.
Old 08-23-2016, 12:48 AM
minibull's Avatar
Tks a lot Andy!
very clear and detailed explanation!
Ony the attached pic not works.. if you can post it again when you have some free time..
Tks a lot.
Old 08-23-2016, 03:00 AM
andyb2000's Avatar
Ah apologies, try again for the image:
Old 08-24-2016, 11:53 AM
minibull's Avatar
changed with a new tungsten but bulb without the blu cap.. the light is better..
rebuilt the two circuit boards..
now it works ok!
tks Andy
jerth
08-08-2021 10:49 AM
MicaX27
05-10-2014 01:19 AM
Daryl Baines
12-29-2008 06:40 PM
miser_chris
07-25-2007 03:57 AM
rsirois
12-15-2006 02:04 AM
Quick Reply: MY05 console led replacment.
