Sponsored by:
Sponsored by:
Error Codes & Turn Off Check Engine
Old 04-06-2008, 02:33 PM
VanJockey's Avatar
Default Error Codes & Turn Off Check Engine
Can anyone offer advice on how to see the computer's error codes? My check engine light is on. I know what caused the issue, but I'd like to see the codes in the computer andand I'd like to reset it to turn the check engine light off. I'd appreciate any help or advice.
Old 04-07-2008, 08:04 AM
jdl's Avatar
jdl
jdl is offline
Default RE: Error Codes & Turn Off Check Engine
If this is a 2001 model, you may have to use an OBD 11 code reader or scanner. Some of the national brand autostores will check codes for free
On some Chrysler OBD11 models, you can get some codes by cycling the ignition switch, not sure that will work on your vehicle.
Old 04-07-2008, 09:24 AM
I wonder's Avatar
well, it's not OBD 11 but OBD II (two).
check engine light can be turned off, but on some cars fault stays memorised in the computer.
everything you need to know is here
http://www.allpar.com/fix/codes.html
Old 04-07-2008, 08:58 PM
VanJockey's Avatar
Thanks for your response. This is very helpful.
Jfizzle
02-22-2020 04:37 PM
Floyd Newport
14
12-09-2010 09:30 PM
e49735
04-25-2008 03:19 PM
contourfreak22
02-14-2008 07:39 PM
webbphoto
06-19-2007 09:22 AM
Quick Reply: Error Codes & Turn Off Check Engine
