No power at left side Head Light.
Old 07-10-2014, 03:37 PM
Default No power at left side Head Light.
2003 Grand Voyager Ltd, 2.5CRD.
Was doing and noting Towbar wiring today, still to add on here. During lighting check, finds left/nearside headlight dip wasn't working. On further testing there's no voltage at lamp terminals. But right side lamp is ok.
Is this a known fault, or is it wiring related. Anyone any solution while I do my Towbar wiring.
Thanks...For the dry weather Too..
Old 07-14-2014, 02:13 PM
Anyone got a wiring schematic of front lights as fault seems to be between lamp and relay...
Old 07-14-2014, 02:28 PM
Tombt's Avatar
I lost power to front left headlamp, it was a wire rubbing through as it leaves the engine bay towards the light assembly, worth checking cos it's a nice easy fix.
Tom
Old 07-14-2014, 05:51 PM
goggsie, 'tfb' put the wiring diags up somewhere on this forum.
Old 07-15-2014, 01:51 PM
Now thats an interesting one from Tombt as when I was under the front end last weekend routing a power wire for tow hitch I noticed a total of 2 wiring sheaths rubbing through, one on side plastic splash guard and another on metal bodywork....looks like I'll need to strip those taped together bunches of wires.
And QinteQ must get a schematic of lighting from ftb's post seeing I'm into wiring at mo...
Old 07-15-2014, 02:23 PM
Old 07-15-2014, 03:17 PM
Raptor 07's Avatar
Still need the diagram? Send me an email address to send them to via a private message.
Wires look good? No relays on your 03. All that wonderful solid state... stuff. Power comes off the Front Control Module - silver box bolted to the front of the fuse box "spade" contacts 3-4-5-6. Many have had success slightly twisting these spade contacts with a pair of needle nose pliers to make better contact. Course this is all US spec. You're Euro spec van may or may not be the same.
Rt low beam - contact 6
Rt high beam - contact 4
Lt low beam - contact 3
High beam - contact 5
Old 07-16-2014, 09:36 AM
Ah QinteQ, got those diagrams last year but all the pictures were blurred as were the schematics, seem to be ok this time. As to Raptor7 here's a picture of alum box on front of fuses, is this it and does it come off to see those spade connects.
Attached Thumbnails No power at left side Head Light.-20140716_151959.jpg   No power at left side Head Light.-20140716_152016.jpg
Old 07-18-2014, 11:22 PM
Raptor 07's Avatar
Yes that's the FCM. 4 bolts and you're there. Disconnect the negative battery cable first
jojo42
02-20-2012 03:41 PM
kentchris
04-29-2009 09:41 PM
playboy00786
11-02-2006 05:43 PM
onedownfiveup
01-20-2006 06:15 PM
onedownfiveup
01-17-2006 04:20 PM
Quick Reply: No power at left side Head Light.
